Are you looking for Water Alarm with Remote Sensor: HY? We found best price for you. Go to link below to buy the Water Alarm with Remote Sensor: HY for the lowest price.
Water Alarm with Remote Sensor: HY Review
I am so happy I bought household sensors & alarms. They fit well, look really expensive and will look great with anything. The Sonin household sensors & alarms are well-made ...
Water Alarm with Remote Sensor: HY Description
Detects Water and Sounds Alarm which helps prevent costly water damage which may not be covered by insurance. Warns of leaks and overflows in bath, kitchen, laundry, furnace, computer rooms or anywhere there is a potential for leaks Low battery signal tells user when it's time to replace the battery Circuit test bar ensures system is working Alerts user within hearing range that water has reached desired level when used to monitor the filling of pools, tubs, sinks, aquariums and more An ideal backup system for sump and bilge pumps in residential, commercial and marine applications Sensor and alarm can be placed up to 6 feet apart Loud 85 dB (decibel buzzer) . Sounds for up to 3 days Uses one 9-volt battery For leak detection: Just place the sensor (suction cup up) at the lowest point of the floor or other horizontal surface where water collects. The alarm will sound if water bridges between the two contacts. Alarm can be table, shelf, or wall mounted away from the sensor. For unattended filling of bathtubs, pools, spas, etc: Use the section cup to attach the sensor to any smooth vertical surface. The buzzer will sound when the water reaches both metal contacts on the sensor. One-year factory warranty.
Related posts
- Water Alarm With Remote Sensor
- Stellar Remote Starter Systems STRS9950 Remote Starter with Alarm and LCD Remote
- Honeywell RWD41 Water Defense Water Sensing Alarm
- 1 Way 2 Remotes Sensor Security System Car Alarm
- Motion Sensor Security Alarm And Chime
- Plug &Amp; Safe Ps10 Portable Sensor Alarm
- Cube Sensor Snooze Alarm Clock by LEXON
- Wireless IR Security Burglar Alarm Motion Sensor Detector
- Remote Controlled Car Alarm System RF (Closeout)
- Lumex Fast Alert Patient Alarm with Pressure Sensor Chair Pad
- Insteon Leak Sensor - Water leak sensor - wireless - 915 MHz - white : Home Automation
- Electric Life Remote Start and Alarm System 95730 Security Alarms
- LCD Digital Smart Light Activated Sensor Bedside Lazy Snooze Alarm Clock with Date and Temperature Display
- Electronic Alarm Water/Fire-Resist Safe, 2 ft3, 18 2/3 x 19 3/8 x 23 7/8
- Honeywell RWD21 Reusable Water Leak Alarm
